‘Sensible’ SatNav routing (1 Viewer)
Sep 26, 2010
625
389
North Wales
Hymer B654
Since 2009
Help! Our TomTom Camper version SatNav (and Google maps of course) insist on trying to route us down roads which are sometimes not much more than country lanes (mainly talking UK routes). It’s so annoying that we now always have a road map handy to ensure we don’t take the suggested ‘shortcut’!
Is there a SatNav out there that only gives routes on A and B roads only and ignores anything smaller/narrower?? Maybe a HGV type SATNAV?
Mar 14, 2020
778
679
Isle of Man
Autotrail Cheyenne
Since 2015, still learning
This may help you make a decision. Unfortunately none are less fallible than your road map
9,793
26,008
Derbyshire
Elddis Accordo 105
since 2014
Use Google maps to see exactly where you are and a paper map to plan your route. Never fails. 👌
irnbru
13,545
31,298
Glasgow
Benimar 264
11 yrs
I don't recommend Garmin its very unreliable but very reliable for those that only use it from A to B in the UK :LOL:
2,344
7,108
Mid Devon
Adria Compact SC
Camping since 1954, MoHo 2022
Try the free app ‘Magic Earth’. It has a ‘Truck’ setting into which you can input vehicle dimensions, overall and axle weight, plus maximum speed.
bigtwin
5,669
10,890
Derby
Concorde
Since 2006
What have you set as your route planning default options?
If you don’t set them up to match your own preferences then you will get some strange routes.
Also, have you set up your vehicle profile and have you selected it. If not, it will be using a car profile.
Finally, have you selected the Camper Map or are you using the default map?
Ian
5,812
60,040
hull
Laika Ecovip 300
Not even good for that can't get us out the storage are without trying to take us into someone's garden or a livery stable, now we know they are wrong, but if it was Johnny foreigner they might well get a bit miffed.
It is however excellent for giving digital MPH/KPH
3,925
10,613
The salty bit of Hampshire
Carthago Compactline
Since 2017
I've got a TomTom Camper and have "fastest route" selected. It will make a beeline for motorways most of the time which, if you are in the wilds, may take you down some 'interesting' roads to get to it. I don't always want to take motorways and often select interim destinations so that it will route me via the roads that I wish to use. Best 'rule of thumb' is ignore anything that has grass growing down the middle. That and get yourself a 'slimline' motorhome.;)
Gellyneck
10,216
20,917
Scotland
More than toes wet now!
All three of my Garmin units are reliable enough for me, just need to check the route before pressing 'Go' to double check.
I use Garmin BaseCamp in line with our Camper sat navs and you can set various pre-installed Avoidances,
and User defined Avoidances.
You can also set road type speed settings so if you stick to 55mph on motorways you set it to that to give closer route point / destination arrival times.
As you say, we still double check the routing results.
JockandRita
11,899
158,944
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Better than the Magic Earth App, is the Road Lords App, especially if driving anything larger than a LWB panel van.
Google maps are great for route planning, etc, but not as a Sat Nav for larger vehicles.
Cheers,
Jock. :)
johnandi
Sep 26, 2010
625
389
North Wales
Hymer B654
Since 2009
Ian
Hi Bigtwin, yes I’ve done all those things. I’ve played around with ‘quickest’ and ‘shortest’ routing but obviously these still try and send you down country lanes. I’ll double check the other options though.
johnandi
Sep 26, 2010
625
389
North Wales
Hymer B654
Since 2009
Thanks, good advice 👍
johnandi
Sep 26, 2010
625
389
North Wales
Hymer B654
Since 2009
The road type avoidance is a handy parameter 👍
4,801
9,332
Greenwich, London, UK
Hymer MLT 570
Having said which, our straw poll on the other thread, the Garmin won the 'Cornish Pub Crawl' route.
Google failed miserably
Nanniemate
6,749
46,598
IH
Road Lords is popular amongst some hgv drivers free and paid versions
3,111
4,579
Wells, Somerset
Elddis 115
since 2004
All sat navs need is a "use major roads" preference. Most sat navs I have used, including camper types, happily send you onto minor roads unnecessarily as you get closer to the target. Or send you off a major road, and later put you back on the original major road. This is where a traditional paper map helps.
133
118
Harmony line 690g
Downloaded Magic Earth App don't see Truck settings on it ??
4,801
9,332
Hymer MLT 570
The "Cornish pub crawl SatNav test route":
I use it to test SatNav's. I know the route well as my mother lived at one end and my sister at the other, with my niece in the middle.
The St Tudy Inn, St Tudy, PL30 3NN
The White Hart Inn, St Teath, PL30 3JX
The Port William Inn, Tregardock, PL34 0HB
The correct answer is:
The route given by Google and others is not realistically drivable in a motorhome as it involves several miles of single track with high hedges (so you will scratch you van,) a 300 degree hairpin bend, and as a minimum any driver must have the ability to reverse half a mile back up a single track with 3" of space on either side up a steep hill and around blind corners.
Google also correctly says the speed limit on the single track is 60mph.
The reality is 15-20mph
bigtwin
5,669
10,890
Derby
Concorde
Since 2006
That’s available on the TT Camper too. 👍
That hasn’t been my experience with the TT Camper.
Ian
589
2,181
Maspalomas, Spain
Giottiline Toscan 74
I use Tom Tom go commercial version and you can add your vehicle dimensions - height, width and weight. However, I cannot guarantee it will take notice of this 😂 but it is certainly much better than google maps.
