Did not have a vertial wall to mount my Victron Orion and did not want to mount it on the flat as the heat sink on the back uses passive cooling so designed and printed a free standing mount that can be attached to a wooden base. I need to measure the size bolts I designed it for but there is a holding enclosure for the nut - think it's an M4 - on the vertical arms. I printed at 0.3mm layer height on it's back in PETG with about 40% infill and 90% infill around the screwholes at the bottom to avoid hearing that "crack" when attaching it to the base. No supports.
