1. Untitled Document
VIN Plate Locations
Discussion in 'MOTORHOME CHAT' started by Jim, Feb 5, 2008.
  1. Jim
    Jim Ringleader Staff Member
    Jul 19, 2007
    Wales
    Hi All,
    Doing a bit of research, I need to know the common location for the VIN Plate on your motorhome, if you could let me know the model and your VIN plate location I would be grateful.
    Thanks in anticipation
  2. Road Runner
    Road Runner Funster
    Jul 26, 2007
    South Wales
    To be honest with the DVLA inspection I told them my VIN number and only interested when I deliberately pointed out my sticker that has year, dates and weights on by the drivers seat.
    They took a lot of notice of my import papers though and took the American embossed title sheet of my bus.
    There is also a makers plate down by my entrance door frame but that gives year and there makers number on it)
    Hope it helps (not sure it will though)
  3. Enodreven
    Enodreven xMember
    Nov 28, 2007
    Hi,
    Mine is on the right hand side of front cross member to the engine compartment, Fiat Ducato 2004/5 base ? with an Alko chassis all of the VIN Plates are there the orginal Fiat and the Updated Alko.
    The motorhome manufacture has a makers plate which carries the same sort of info which is sited in the step well to the habitation door.
    Swift Bessacarr E735, Fiat 2.8 JTD
    Is that the sort of info you are looking for
    Brian
    and by the way system seems to have slowed down again, mainly when opening a thread
  4. motoroamin
    motoroamin
    Aug 12, 2007
    North Notts
    From memory, this should cover a few:
    Fiat Ducato/Peugeot Boxer/Citroen Relay - Front cross member beside bonnet latch (there may be an additional upgrade/AL-Ko plate also) On late models it will also be stamped on the chassis under a cover in the drivers' footwell;
    Iveco/Mercedes - usually fixed to the side of the drivers seat, or adjacent if 'A' class non-standard seat;
    Renault Master - on the vertical door pillar, drivers side;
    VW - long plate visible at base of passenger side windscreen;
    Ford - ??? can't remember
    Don't forget that chassis VIN and motorhome VIN are two different things eg a Hymer VIN will be on adjacent to the caravan door on the skirt, others are inside the door, in the glovebox etc... HPI and DVLA records are normally against the Chassis VIN.
    Hope that helps.
    Chris.
  5. johnsandywhite
    johnsandywhite
    Jul 29, 2007
    Doncaster/Spain
    1988 Coachmen Classic - inside floorwell of the drivers side.
    1993 Gulfstream Crown Regis - Original was a metallised plastic stick on wrinkled plate above the drivers door. Replaced with a new one on the entrance door stairwell. (Don't ask how I go a replacement?)
    1996 Newmar Mountain Aire - inside floorwell of the drivers side.
  6. pappajohn
    pappajohn Funster
    Aug 26, 2007
    scarborough, nth yorks
    2001 kontiki.
    same as brian's but not sure about the hab' door stepwell (not taking M/H cover off to look :Angry:)
    john
  7. Tony Santara
    Tony Santara Funster
    Jul 26, 2007
    Cheshire (ex Mancunian)
    Winnebago C class inside edge of drivers door frame
