Vehicle and Leisure Batteries (1 Viewer)
Aug 23, 2011
204
495
Huntingdon, Cambs
Lyseo 727g
since 2011
Our bus has recently come back from work at Swift (hah!) and, ever since, we have had problems with starting in that if the vehicle is left for over a week then it will not turn over.
Looking at the two batteries fitted (1 in the cab (Vehicle battery?) and one in the belly locker (leisure battery?), they both have the same code, namely LB6110L. When I google this code then the description is for a leisure battery.
Does this mean that I now have two leisure batteries fitted and thus the problem in starting?
Sorry about the silly question, but since dealing with Swift I am beginning to doubt my own sanity.
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
Since 2012
Either you have two leisure batteries and haven't located the engine battery, or someone is using a leisure battery as an engine battery.
Even if this is the case, that leisure battery is rated for around 750CCA, which would start even a large high compression diesel. If it is not working, you either have a high drain somewhere that flattens the battery, or the battery is knackered. (The former often leads to the latter).
Obviously, if replacing the battery replace with an engine one rather than leisure.
I've got battery isolators on mine and just disconnect the batteries when leaving. None of my electronics/alarms etc seem to care.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
I too suspect you havn't found the engine battery yet:winky:
By in the cab do you mean under a seat or floor panel or in the engine bay itself
If under the seat or floor area it is most likely a second leisure battery two the same is a good sign:thumb:
Open your bonnet and look for a third battery in there:thumb:#
This will be the one going flat and preventing starting
You dont say what age the batteries/vehicle is/are or what work you have had done
G
Binky
Aug 23, 2011
204
495
Huntingdon, Cambs
Lyseo 727g
since 2011
G
It's a 2010 Peugeot Boxer and what I believe to be the vehicle battery is under a panel in the passenger footwell. The vehicle went back to Swift to have new locker doors fitted due to high damp readings (it was with Swift for 10 weeks - but that is a whole different saga). They had moved some of the cabling/alarm wires to fit troughs on the floor behind the locker doors, so I am assuming that the battery was unhitched/removed then. It just seems coincidental that the battery/charging problems started when it came back from Swift, but I suppose the battery could have become u/s whilst it was sitting around for so long.
Apr 18, 2009
3,569
3,367
Englishman in Mid Wales
Hymer B584, A Class
Not long enough!
Wouldn't worry to much about them both being the same as most batteries are the same:Doh: even if badged as leisure, Marine or starter:thumb:
Feb 27, 2011
14,698
75,581
UK
Self Build
Not quite. The cranking amps can be different. I got the wrong battery in my van once and it took forever turning over before it started (brand new battery fully charged) Swapped it for one with the correct cranking amperage and it starts in under a second.
PS: Both were starter batteries. So even two batteries from the same manufacturer can be different internally..
callumwa
4,110
4,480
Tyne & Wear, sometimes..
4 yrs +, 30+ yrs motorbike touring
Our van is a 2009 Pug Boxer.
The one under the panel in the passenger footwell is the starter battery...
::bigsmile:
Apr 18, 2009
3,569
3,367
Hymer B584, A Class
Not long enough!
Shoulda bought a leisure one:winky:
