Using laptop as a tv (1 Viewer)
Aug 5, 2012
125
99
Southampton
van conversion
since 1981 on and off
we used to worked well. Ariel needed. Changed to wire to standard co-axel cable plug.
Al1
49
19
As above and used Windows 7 media centre to view.
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
If you buy a cheap USB video grabber you can take a composite output signal (ie yellow, white/black, and red plugs) from your Freeview or Freesat box and feed it into a computer via the grabber's USB plug. To view it you need some sort of video editor software that accepts the signal as input - there's plenty of free ones.
Obviously you need a dish in place, or a decent aerial of some description for the Freeview box.
We don't have a satellite dish for the main home TV, but I've got a cheap Aldi portable sat dish and receiver attached to my conservatory, which feeds a signal into my PC via a video grabber if I want telly on the computer. This means I can now watch 937 different channels of men in turbans chanting whenever I want.
Feb 22, 2008
12,262
45,045
Norfolk
Nearly Tugging
Since 2004
Only when out of the country where can't get satellite but can get reasonable wi fi and use filmon
Sep 23, 2013
2,585
8,773
Lincs
Globecar Campscout
Yes - a plug in USB tuner & Windows Media Centre - which is better than most of the freebie TV programs that usually come with the tuners.
You need just as good an aerial as you do for any other telly though, so you can't compromise on that. I have a 12v powered Avtex aerial with built in signal booster - forgotten the model number off hand, but it's their standard portable one. Again, the ones that come with the tuner are only any good in very strong signal areas.
Apr 9, 2013
663
373
Ayr
Newbie
Tivizen is a great gadget that allows you to watch TV on your phone, tablet or laptop. It's a freeview tuner that rebroadcasts on wifi to connect to your device.
We have the nano which is handier than the USB version as you can move it around for best reception.
http://www.tivizen.com/wifi-dongle.html
