Tuition for Newbie (2 Viewers)
Mark5204
229
60
Bristol
Swift
Newbie
Hi just a long shot really. Are there any members in Bristol area with a 54 Swift Kontiki that would be willing to give us a tuition on how things work and advice on draining down waste water etc. Complete novice.
joncris
1,101
1,603
Where it matters
Rimor Katamarano 12p +
Hi Mark
I'm sure if you search the forum you'll find lots of info regarding your MH
There is a section which covers MH's both British & European
DanielFord
3,020
3,086
You'd also need to say which model Kon Tiki, different layouts have things in different places.
DanielFord
3,020
3,086
Just looked that up. The layout is very similar to our Sundance 630L. If ever you find yourself in the Dorset area, I may be able to help you. (y)
1,086
1,012
somerset
coachbuilt
Mark I think yours is similar to my bessycar I live in bridgwater if your down this way , just ask loads of quetions on here they will get answered im still new to mine, You will get help on here regards steve
MikeandCarolyn
2,170
1,468
Worle,North Somerset
Since 2009
Of course lay outs vary from van to van-but there are basic principles as with most techy things.
Finding where things are can be tedious but great fun :LOL:
Do you have any specific queries ?
Mike
Mark5204
Mark5204
229
60
Bristol
Swift
Newbie
Thank-you very much Steve. We are picking it up slowly . hope you are enjoying your bessecar lovely MH.
Mark5204
Mark5204
229
60
Bristol
Swift
Newbie
Mike
We are getting there slowly. Sorted one or two issues out.
2,932
9,922
North Essex
Autotrail Delaware
>12 but <13
We learned the hard way. (Kontiki 650) Filled with water then noticed river below, ah yes, lift carpets then trap door and insert rubber drain bung into fresh water tank. Now full but no water from taps but river below, oh yes, lift carpets and trap door and flick drain plug off. Tested fridge on 240v, didn't work, read book, my model has separate wall switch it tells me, no it doesn't, is it the one in this cupboard behind these bottles wife asks?
How do I get parking lights? Put side lights on but go off with ignition. Asked here and had reply in minutes. You press in button below key and key goes anti-clockwise one extra click, then remove key!
The fridge fan never worked, but then in France when it went over 30c it did! Ah I see why now.
Enjoy
Mark5204
Mark5204
229
60
Bristol
Swift
Newbie
Enjoy
lol. Couldn't have put it better myself. Not tried filling water tank yet.... Or draining waste water. I agree handbook not very useful for a novice.
Thank-you for parking light tip didn't realise that. I had noticed all lighting goes out with ignition off. Will be trying that in the dark tonight. Have fun very useful advice too. Thanks
MikeandCarolyn
2,170
1,468
Since 2009
In 6 yrs I've never had occasion to use parking lights :) So,I would have to find out how to :LOL:
Mark5204
Mark5204
229
60
Bristol
Swift
Newbie
Lol. I only thought of it when we collected MH. Stopped at shops in dark and all lighting went out. Couldn't get lights to stay on at all.
MikeandCarolyn
2,170
1,468
Since 2009
Oh BTW,when you're filling tank listen for sounds of water coming out below van:) Boiler auto-dump valve could be open in this weather.
Similarly when you've bled water system and got it all working,have a look underneath just in case.
1,086
1,012
somerset
coachbuilt
yeh i had same with fridge switch and also mark make sure cooker lid is right back or cooker wont work isolation switch is there regards steve
Mark5204
Mark5204
229
60
Bristol
Swift
Newbie
Lol what's the boiler dump valve. I have a lot to learn.
MikeandCarolyn
2,170
1,468
Since 2009
Most boilers have a valve which opens when temp drops and there's a risk of freezing-I think it's around 5-8 deg.
Valve will be usually adjacent to boiler and would need resetting if it trips-I have clamped mine in open position.and am very carefull when temp drops.
Mark5204
Mark5204
229
60
Bristol
Swift
Newbie
oh okay. Thank-you something else to look for tomorrow..list is getting longer lol
MikeandCarolyn
2,170
1,468
Since 2009
Here's a couple of pics of truma dump valve on my LMC (same year)
Valve is closed when red knob is up .
Photo4x4
371
873
Scottish Highlands
Coachbuilt with over cab
Newbie
We purchased our Bessacarr E495 in July last year and I'm still learning!
One of the problems is that the owner's manuals tend to be generic and not everything in the MH is exactly the same as the manual so don't worry about being a bit confused or overwhelmed Mark.
When we first got our MH I was going through the 'setting-up' procedure but couldn't get the gas to work on the stove. I did everything the manual says and I even had my brother-in-law, an experienced caravaner, take a look, however no joy. I then telephoned the technician at the dealership where we purchased it.
I was about to go and buy a new gas cylinder when I decided to read the manual again for the umpteenth time. This time I noticed that it said "Push in the control knob (on the cooker) and turn to full rate..." (my italics). Bingo, on came the cooker!
When you think about it they operate this way so you can't accidentally turn on the gas.
The 'quick start guide' tells you to "Press ignitor on hob, turn one burner control to 'ON' and depress that control." Which is the opposite way to what the owner's manual says, I suppose that it works either way but when you are new to this and are a bit overwhelmed it can be rather confusing.
Either way I missed the bit about pushing in the knob. Doh! My only compensation is the my B-I-L missed this as well.
Anyway Mark I have found that the quick start guide is a great help in 'setting-up' and is in general easier to read than ploughing through the manual. After you have done it a couple of times it becomes second nature.
Happy holidays, you are in good company!
Keith Hart
