is it legal to tow a trike on a doly in spain france the bloke i brought it of gowes to germany all the time and told me it is legal he brings them back on them all the time
it has 2 wheels you lift the front wheel of the trike in to a hole on the doly and that is it. then all you have is just the 2 back wheels on the road it toes great i have tried it. you can find the dolly on thr trike doctors site
If the back wheels are on the floor the brakes need to work, it becomes a trailer in principle and trailer regs apply, brakes fitted they must work irrespective of weight. That said, and I'm sure Bob will be off soon but technically I don't think you'll find it legal here, not illegal also so a grey ish area, ie you'll probably get away with it, but you'll still need working brakes.
As to Europe, no idea, apart from the much discussed Spanish side which will be a firm no.
Just seen Dave's post, same applies, brakes required to work, sad really as it would be a fun way to do things and lets face it with the weight of a trike the RV will never know it's there, or be affected by it.
A friend has a braked 2 wheel ambulance for sale that we were going to convert to fit Joys Boom trike on...problem was the trailer wouldnt fit up the side of her house so it was a no goer.
Its perfect for putting a trike on as its low to the ground and has short built in ramps fitted...if you decied to go down this route PM me.
Just a thought re Joy's trike and towing, one thought I've had in the past were there is a storage issue is, trailer in garage with hitch in ball on suitably secure post and simple park the vehicle, ie trike on trailer in garage?
Don't know whether that would work, thought I'd throw it non the less:thumb:
I think there was a problem re where the garage was situated,the garage was at the rear of the house and you had to go down the side of the house to get to it. The trike would fit down but not the trailer.Just a thought re Joy's trike and towing, one thought I've had in the past were there is a storage issue is, trailer in garage with hitch in ball on suitably secure post and simple park the vehicle, ie trike on trailer in garage?
We have a huge garage, that was fulloh: and one plan was to have a car trailer and due to garage size do this, but we're going a different route these days. My thought was if small enough it may work you see:thumb:
I know Simon a fold up car.. well near as.. bits of the body hang out ... you are going to need a jib on the back of your RV to carry it (off the ground).. But a small trailer might work if it is light enough.... If I had two legs I would need one for each foot.. that is what I used to say about a Fiat Cinquetrento we had with a sun roof.. one for each foot. :Blush:
Bob:thumb:
Oh yes there is......in best panto voice.I know this is an old thread.
However as most trikes are under 750kgs there is not a requirement to have brakes working.
Trailers, mini caravans etc under 750kgd do not need to be braked.
Incorrect.....PJ, yes, if over 750kgs MGW.
Trailers having a combined axle mass not exceeding 750kg are not required to have brakes fitted.
However, if the trailer (regardless of mass) is fitted with a braking system, then all brakes in that
system must operate correctly
Hi, aside from the brake regulations as my trike is an auto has anyone towed a trike on a dolly with its back wheels on a dolly??Hi Lyndon,If you are considering a dolly...why.
Would it not be easier to have somthing made up to slide into the tow reciever and just lift the front wheel onto it.
How heavy is the front end of the trike...if you can lift it then its not necisary to have the dolly.
Have seen a few of the trikes towed around like this...of course it would have to be manual trans and not an auto.
Dave.
