thetford fridge probs (1 Viewer)
escapee
52
28
northants
ewift escape 686
since 2009
hi all
in france at mo in heat wave with the fridge not working on either mains or gas
Loads of heat being expelled out of vent but no cooling inside Have bought a cooler box to see us through until our return next week when i expect ill have to look around for another one unless anyone knows of a cure
cheers
TerryL
6,211
8,223
North East
Low Profile
Just a thought if there is a lot of heat coming out of the top vent, something is working. Does it cut out when it's cooler i.e. at night? In the current heatwave fridges do struggle. Try not to open the door too often e.g. "to check", and also the door seal is good.
If it is the fridge I've read on here that taking it out and turning it upside down sometimes revives it. Don't know if that's possible where you currently are.
teknik155
204
180
irthlingborough
c class
since 2002
I don't know if this will work for your fridge but I messed around with the electric temperature setting knob and turned it back to 0 and there was a click sound . I lost all temperature on gas and electric. When I got home the first thing the domestic engineer did was to turn the knob back to 0 and made it click again and its worked perfectly since. I can't remember what his explanation was as it was 4 or 5 years but I think I turned something off with the 1st click and it only worked after the 2nd click.
I don't mess with things if they are working.
escapee
escapee
52
28
northants
ewift escape 686
since 2009
sorry for late reply am back home now and have removed the fridge and turned upside down to burp it which didnt seem to work the first time so have done so a second time and will be testing it out tomorrow when we go away for a few days will also try turning the knob off and back on again as suggested
thanks for your replies
