DarrenGuest
I own a 2008 Swift 590RS which is based on the Fiat Ducato Chassis. I have a problem with the lights and wipers which I think may be related. For a while I have had a problem where the wipers have intermittently stopped working. This has got worse and worse and they are now not working at all. I also have a problem with the dipped beam lights where they turn themselves off. The side lights work fine but as soon as I switch on the dipped beam they only stay on for a few seconds. You can hear the relay under the dash click as they switch off.
After doing some investigation I have discovered the following :
1)With the engine off the dipped beam lights seem to stay on with no problem.
2)With the engine running they switch off after a few seconds.
3)If I switch on the hazards I can hear a relay behind the drivers seat clicking on and off continuously. When this happens all the lights flicker slightly. After investigating the fuse panel behind the seat it is the main fuse box for motorhome.
I have run out of ideas now and was wondering if anybody else had experienced a similar problem or could recommend someone to investigate if for me in the Surrey area?
Many thanks
Many thanks
