Scart Lead (1 Viewer)
milpol1
80
24
Earth
2013 Hymer
Since 2011
I have a scart lead which im trying to fix to mt sat receiver and tv, however there is aswitch on the top of the scart connection, any ideas what its for??
D
Deleted member 29692
Are there any markings or words by the switch? There are a couple of things it could be. The most common one would be IN/OUT which if you are connecting that end into your TV would be set to in, if you are connecting it to the output of your sat box it would be set to out.
lunarman
2,155
2,451
South Glos
since 1994
Is the lead Scart to phono plugs? If so its a bidiretional cable the switch is to reverse the direction of the connection i.e. scart out/phono in to scart in/phono out
M
milpol1
80
24
Earth
2013 Hymer
Since 2011
Thanks both, it is scart to phono plugs. Got it, now to try and tune MicroM30/12 HDMI into the TV, I am not a techy so it may take a while
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
Also bear in mind that not all SCART plugs are connected in the same way, in that some have more pins than others. They all fit the SCART sockets on the devices, but they may not perform all the required functions.
