rubbery smell from traumatic gas heater (1 Viewer)
Oct 1, 2014
115
47
Does anyone else have this problem when heater is turned up high...Any ideas how to cure thanks...Dave
cliffanger
4,835
34,010
Saltford
Hymer A class
Since 2013
We do but you get used to it after a while! We've had our 2006 Hymer B564 for two years now - and it still smells rubbery when the heater is switched on.
scotjimland
2,300
9,952
A Woosh bang
From a previous thread..http://www.motorhomefun.co.uk/forum/threads/truma-heater-c3402.94356/#post-1138232
check your heater details.. this is an old recall but worth checking..
There was a recall of the c3402 sometime ago for precisely the symptoms you describe. More details can be found here including serial numbers of affected units.
http://ec.europa.eu/consumers/safet...m?event=main.weeklyOverview&web_report_id=181
Description: Heating appliance Truma
Type/number of model: Heating systems, authorisation numbers:
e1*2001/56*2004/78*0146
e1*2001/56*2004/78*0147
National authorisation number S 300;
Trumatic C 3402 (E);
Trumatic C 4002 (E),
Trumatic C 6002 (E)
and Trumatic C 6002 EH,
Factory numbers:
C …. 16 255 001 to 17 159 000
C EH…. 15 329 001 to 17 159 000,
Country of origin: Germany
Fire,
Injuries
In pure hot water mode (summer mode), it is possible that the heating system may overheat, which in extreme cases may lead to a fire in the vehicle interior.
A possible malfunction of the heating system can lead to the overheating of casing parts. In extreme cases, this may lead to a local fire. The thermal overload can lead to a noticeable smell developing. The manufacturer recommends not using the heating system until it has been examined.
Reactions: GJH
GJH
29,450
38,827
None, now sold
2006 to 2022
I kept forgetting about this recall but finally got round to checking this weekend. The heater works OK but, from time to time, we have detected a smell when it is in use. Although it appeared, from the serial number of our heater, that we should be OK I sent a message to Truma just to make sure. I sent the message on Saturday afternoon and received the following reply at 8:15 this morning
The serial number for your heater indicates that this falls outside of the range of heaters affected by the safety modification. You should be aware that when the heater is on water heating only the unit does get very hot and will smell warm, this is because the air circulation fan is not running so does not dissipate the heat build-up around the unit.
If you require any further assistance do not hesitate to contact us.
Full marks to Truma for a fast response and for the detail of their reply, which gives us reassurance.
TeeCee
123
36
romford, essex
Bailey Autograph 79-4
Since 2011
Sorry that this is a bit of a late response to this thread,,,,but mine stinks too...not always...but also seems to run fine for a while and then cut out for no apparent reason. Anyone else get these symptoms? Have to say that the smell is more than a little worrying.
TeeCee
123
36
romford, essex
Since 2011
Sorry to repeat this question but....my Truma Combi system seems to work fine (apart from aforementioned smell) but from time to time seems to cut out for no apparent reason. (ie red warning light comes on).
So....any ideas why this happens?
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
Can I suggest calling truma if you're concerned . Their customer service us excellent (in my opinion) .. they are near Burton on Trent if you're nearby.. you could make an appt and pop in and see them
GJH
29,450
38,827
None, now sold
2006 to 2022
I agree, get in touch with Truma for advice. As said above, they give excellent customer service.
