Rear view camera through the wall fitting PART I (1 Viewer)
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
This little camera is quite pricey at £56 but it is claimed to be Sony CCD
Comes complete with a 28mm hole saw and is primarily made for bumpers so comes with a couple of angled tubular collars to adjust the angle.
Mine is going through the flat & vertically plumb rear wall so I discarded the spacers and to my delight realised it is now long enough to go right through the full 29mm thickness and still get the securing ring on.
I kept the piece of wall that I cut out for the external 230 volt socket as I knew it would be handy at some time even if only for dimensions or just to show people how the wall are constructed (Rapido)
The hole was straight forward making sure it goes through at 90 degrees!
The camera has it's own O ring so no sealant needed.
Part II will cover pictures in place on my van plus rear view shots as seen on the monitor
This is for when reversing and is a supplement to the high level rear view camera I am fitting in a seperate topic.
A bike rack makes a dual camera disfunctional when bikes are loaded.
mapa
29
42
Colchester
coachbuilt
newbie
Thanks for that, very interesting. I too have a double cycle rack so am interested in solutions to the twin camera problem as the rack gets in the way.
eddie
8,144
41,181
Taunton Somerset
RV
since 1989
They can be used for side view cameras as well. I've used one for two years and am please with the way that it works.
Dec 6, 2011
11,554
25,338
South Wales
Coach built Adria
i fitted one of these 2 years ago been great; was £40 now £49.99
simple to git came with hole saw.
Feb 9, 2008
8,943
18,693
Corby, Northants
Coach Built
I find your posts extremely well laid out and very informative.
Just wandering if there is any likelihood of you doing one for the cleaning of a flue/burner arrangement in a 3 way fridge in the future?
Jan 22, 2013
1,252
59,465
London SE
A class Adria vision I707
since 1971
Hi I fitted a pair of Sony ball cameras that are adjusted and locked using a Allen key, very easy to get the viewing angle you need, they are small and uninstrucsive and easy to fit,
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
If and when the need arises yes I will :thumb:
Although Martin "funflair" has done this himself send him a p.m. perhaps
