Question re TV Aerial Splitter devices (1 Viewer)
Emmit
8,026
17,706
Cornwall
Pilote Explorateur
Jan.2014
Greetings,
In the 'van we have a TV Aerial Amplifier in the wardrobe. That is where the aerial lead from the 'Flying Saucer' aerial (Yes I know:ROFLMAO:) arrives inside the van.
Also in the wardrobe is an aerial lead which comes into the van via a purpose made Vision Plus exterior aerial socket. This was apparently fitted by one of the previous owners in order that a Vision Plus (other brands are available) aerial can be fitted to the back ladder.
So far we haven't had any problems using the flying saucer but I'm sure there will come a time when I have to get the directional aerial out.
NB. Please don't tell me to remove the already fitted Saucer. It sits above the cooker and a directional aerial can't be fitted or accessed there.
Here comes the question. The terminals for 'Aerials' have F Type connectors, as does the Amplifier. Rather than have the situation where I have to unscrew and rescrew the aerials from the Amplifier depending on which aerial I am using, would it be feasible to fit a TV Aerial 'Splitter' immediately below the Amplifier using the Splitter in reverse so that both Aerials enter the Splitter on the 'OUT' and one aerial lead comes out of the IN to connect directly to the Amplifier. In this manner both Aerials would be connected in tandem
(Or would that cause confusion in the signal being received.)
Apologies for the verbosity of this question and any replies will be gratefully received.
D
Deleted member 29692
You could try these:
Broken Link Removed
TheBig1
17,602
43,073
it wont work right as the 2 aerials will work against each other. better to fit quick fit connectors so you can just pull one out and put the alternative in
Broken Link Removed
Emmit
Emmit
8,026
17,706
Cornwall
Pilote Explorateur
Jan.2014
Hi Nic Nac,
Thanks for your reply but surely all I would be doing with that would be adding converters. What would that achieve?. The amplifier has F Type connectors. Are you suggesting that I 'convert that terminal as well.
D
Hi Nic Nac,
Those are F connectors
Emmit
Emmit
8,026
17,706
Cornwall
Pilote Explorateur
Jan.2014
Hi Again,
I replied to Nic Nac without seeing "The Big Ones" answer.
I'll get the converters put on (and create a suitable tail off the Amplifier) so that they aren't working against each other.
Thank you both.
Regards
