wingman
Help/advice required. Due to another Funster asking questions about Sat TV, I got mine out to try.
Despite trying almost everything, I cannot get my satellite system to show more than 83% on the signal intensity and 14% on signal strength (as monitored on the TV satellite setup page). Here's the checks made so far.........
All connections checked/double checked.
Dish feed cable swapped
Receiver boxes swapped (I have a working spare)
Voltage to LNB checked
TV Scart connections checked and swapped
I've also linked up a small portable case-type that I have as spare and done similar checks with that system.
I'm aware that minor movements of the dish are required and all of the paraphernalia that goes with set up BUT, there's hardly a damn signal to start with, let alone moving the dish milllimeters at a time!
A signal strength of '14' remains, even if I unplug the lead at the dish end!!! The result is the same on both kits and the case-type worked ok before, even in the garden which is where I'm trying it all out now.
Anyone any ideas I've wasted a whole sunny and hot day!
