No doubt a topic that has been discussed.......cleaning motor home roof. (1 Viewer)
Oct 1, 2014
44
49
Kent
Autocruise
2 weeks! def Newbie......
After just recently purchasing our new MH which now has pride of place on our drive....I was wondering exactly how to clean the roof?.....there is no rear ladder.
I am aware about the use of power hoses not being used, but I want to ensure the roof is protected as good as possible from the elements and bird poop!, also maintaining the solar panel.
so any tips on wax / shampoo and ladders used would be appreciated!
Jan 22, 2014
1,656
1,140
Birmingham
Coach built
I send the wife up ....:clap2:
4,270
11,305
Home of the war horse
burstnar T640
What you need is one of these a rosey
My life expectancy has now been reduced
I don't expect to survive the goth weekend rosey will kill me
scotjimland
2,258
9,785
A Woosh bang
I use Graham's method.. a multipurpose ladder that can be used as a platform ..
like this Broken Link Removed
It can be used to reach really awkward areas like above the windscreen, especially if you have a luton body .. this with a decent car wash brush that takes a water supply is all you need.
Unless absolutely essential, don't go on the roof.. not only is it dangerous, especially when wet and slippy, I've read several tales of people falling off and ruining their next holiday.. but even if strong enough, your weight can distort the roof panel and break the seals around the roof lights ..
If you must go on, use something to spread the weight, like a scaffold plank.. I've always found bare feet gave me the best 'feel' and less likely to slip.
I used to go on the roof of my RV , but it had a very strong roof, composite plywood with a rubber membrane.. quite different from most European motorhomes, it did not bend or buckle under my weight and being so big it was a lot easier to use a deck scrubber and hose to get the muck off.
Plenty of propitiatory caravan cleaning products on the market.. most have a favorite... I like Silky but you can use any car cleaners. Traffic film removers are very good.. Screwfix have one at about £3 for 2lt and if nothing else avaible use washing up liquid..
If you have an awning, now is the time to also give it a good clean.. my method is is simple, very effective and cheap..
Bucket of warm water , good squirt of Fairy and 1 cup of cheap thin bleach.
Open the awning and wash BOTH sides with a soft broom or car brush.. roll it back in while still wet and soapy.. Leave for half an hour.. open up and hose off.. brand new awning. !
Inthezone
146
105
Berkshire
personal I go up on the roof and only you are in a position to decide if your fit and agile enough to get up there and work also it depends upon your weight, apart from the above I use a hose and bucket & sponge, it doesn't take that long and it gives me the opportunity to check the condition of the ancillaries fitted on the roof, I am also sad enough to polish it with autoglym. I do it about four times a year then wash and polish the rest of the van. Back to how I do it is use a ladder with foam rubber on the part that touches the van at the edge where the roof meets the side wall.
Reactions: SMB
johnp10
7,774
15,181
North Lincolnshire
8 years ish
I have a ladder with pillows taped to the top.
Can do it from each side without going on top.
I used to stand on the garage roof to reach, but that stopped when I went through. (It wasn't an accident, it was stupidity.)
Broken ankles and toes isn't good.
Instead of a month's trip to Italy I had a month in a wheelchair.
In anticipation of a reply.......
Graham, Shuttit!
Plan B:
Get a vehicle valeter to do it.
Forestboy
5,023
8,338
Forest of Dean
A Class Hymer B694 tag
I do mine once a year in the spring always go up bare feet bucket and long handled brush. Give a good wash with a wash n wax. While up there check everything is ok 15 minutes job done for another year.
movan
21,492
120,753
Moving around
Burstner
since07
I believe these two gentlemen may be available for rent to the right people .......
Andy63 and Busman. :)
574
250
Guisborough North Yorkshi
Malibu T410
Since August 2008
We have the Telescopic Ladders from Maplin
Broken Link Removed
They are often reduced in the sale.
Steve is washing the van roof at the moment on the site at Thirsk Racecourse.
FJmike
972
1,046
Swindon
over ten years
Here a few of my thoughts :-
Power/Pressure washers - If you use one make sure that you have a wide fan and keep it moving otherwise you might damage your van.
TFR or Traffic Film Remover
- There are a lot of different makes of TFR and a lot of them contain caustic which burn the dirt away. ALWAYS read the dilution instructions, because too strong a dilution will result in your graphics disappearing and or bleached white run marks down the side of your van.
Ladders - I always use lengths of pipe insulation, which protects the van and prevents slipping. I use a multi ladder similar to Grahams (Maplins sell them)
Fairy Liquid - No no no, it contains salt as well as lots of other nasties and definitely no bleach please Any good car shampoo will do the job, just make sure you use lots of water before shampoo and after as your van will be covered in fine grit.
Walking on the roof - I always make a judgement call before venturing on to a customers roof.Most modern vans are OK to walk on the roof occasionally.
weebill
65
84
aberdeen
Coach built
since 2006
I don't like to walk on the roof so I open up the heki to its full extent and clean all around as far as I can reach, this includes the solar panel.
Then the outer edges are washed down from on top of a multi ladder much as everyone else uses.
mobic
15
8
Linlithgow, West Lothian
5 years
I use an 'H' frame, with an 'A' step ladder secured at right angles with bungees. Rectangular wheeled
bucket, long handled soft bristled brush, Motorhome/Caravan cleaner, Black streak remover all ex Aldi or Lidl
and a fair dollop of elbow grease. If it's a bit windy add a wetsuit for good measure.
Also used the 'A' and 'H' for redoing the vinyl graphics.
Regards
Mobic
Mousy
3,485
20,319
Sa15 2DG
Hymer S840 Merc auto
Since 2013
We've just cleaned our awning using Graham's tip, it's come up great. Thanks.
1,414
3,156
S. Ayrshire
The usual
Since the beginning
Luckily there's a vehicle valeter right next to the the compound where we keep our motorhome.
£30 to wash and polish. And extra £10 t0 do the roof. Comes out looking like new :)
Badknee
7,407
412,104
notloB
Vantage Neo
Living the dream.
My plan is not to feed our stick thin 22yrs old for a couple of weeks then send him up on the roof to give it a good clean before winter.
There are laws against sending him up chimmerlies but nowts been sed about motorhome roofs. :LOL:
scotjimland
2,258
9,785
A Woosh bang
just re-read Grahams notes and don't see anything about cleaning the awning.. what was the tip ?
EDIT..
apologies..
I jumped to the end of the thread and missed your reply to Graham..
glad it was a success !
Reactions: GJH
scotjimland
2,258
9,785
A Woosh bang
Since it was me who mentioned bleach and Fairy you you must be referring to my tip on how to clean the awning.. ?
it was a tip I read in an American motorhome forum, all I know is that it works and has never caused any damage to the fabric,.. .. it will remove all the nasty bird poo etc .. which will burn the fabric if not removed.. done correctly and flushed with plenty of fresh water it brings it up like new ..
I washed mine every six months or so and it looked like new when I sold it..had it for 5 years
I wasn't suggesting this solution to clean the bodywork, graphics etc..
Would be interested to know your method and what product you use.. ?
scotjimland
2,258
9,785
A Woosh bang
How do you make the 'call' .. which roofs would you not venture onto .. and do you ask permission from the owner before doing so ?
most coach built van roofs are a very similar construction, ie ally sheet with a wooden frame.. not many have a fiberglass roof, if you venture near any roof furniture you risk breaking the waterproof seal.. if you were valeting mine I wouldn't want you walking all over the roof.
GJH
29,450
38,827
None, now sold
2006 to 2022
Interesting to read Mike's post as it shows the difference of approach between different professional valet services.
At Peterborough last year a van close to use was cleaned by a company exhibiting there. They were walking on the roof and using pressure washers in a manner that I should not have liked on our van. Granted the roof was pretty dirty (I can't remember the reason but the owner hadn't been able to do it for a while) but the treatment struck me as a bit too rough and risky.
FJmike
972
1,046
Swindon
over ten years
First and foremost if a customer says no walking on the roof even if it is a brand new van the customer is always right. Generally speaking I look at the age of the van and then having cleaned a considerable amount of motorhomes I can usually see if the roof is strong or not, there are some makes that I will not walk on the roof, but if there is any doubt then I will not venture onto the roof. I don't know which company Graham is referring too but having worked for a dealer and attended shows prior to opening I have seen some extremely bad behavior of so called valeters. Because of the volume of work some of these companies employ casual staff that have had little or no training so they see nothing wrong in blasting away at motorhomes.
davejen
1,861
1,235
Preston
Given up travelling
Since 1992
I've cleaned the roof of the Autotrail, EXCEPT for under the solar panel, which has a gap of about an inch to the roof, any suggestions for getting it clean?
Thanks in advance..
Cheers, Dave(y)
