Hi all, after advise from you knowledgeable lot, just had m/h serviced, 2015 690t Burstner, was advised side marker light not working so they replaced it no problem, on getting it home I noticed the rear high level lights ( which are red/clear type) were only lighting up the rear red section on both sides and only come on when engine running so purchased new lights and they are the same, only lighting up rear red section, my question is it correct that the light only come on when lights on and engine running also should both red and clear sides of light come on, thanks in anticipation, simple job turned into bit of nightmare
