Lenny HB
- Oct 18, 2007
- 59,614
- 187,134
- Carthago Compactline
I know there are a lot of members out there still running XP, I still have 2 PC's running it.
There is a very easy way to do it, you just have to create a registry entry that fools Microsoft into thinking your version of XP is the embedded version (Embedded POSReady2009).
It really is very easy all you need to do is:
Create a text file with the following (you can copy & paste), I suggest you use Notepad.
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\WPA\PosReady]
"Installed"=dword:00000001
Now save the file as a .reg file, e.g. xp.reg, do make sure it is a .reg file and not a .reg.txt file.
Now navigate to the file you just created, double click on it and it will install in the registry, you should get a warning message if you have done it correctly.
I recommend going to Security Centre in Control Panel and make sure Windows updates are turned on.
Re-boot your PC.
Now one last thing, the first update you need to do manually, click the start button then click "Windows update" or you can do it via IE.
IE should open with the update page which will run a check on your machine and download & install necessary files for the auto updates to work.
You will now receive updates until April 9th 2019.
Re-boot your PC.
