You might get a bit wet if you try to access it from underneath.Hi All
Would like to remove the end of the hose that came off whilst filling with water from my fresh water tank
Not had a proper look yet as I’m away but would I find access under the van?
thanks
*hand!Thanks All
I’ve found it under a drawer located at the end of the bed. Got my had in but can’t really access the whole tank so no joy.
Last van had a tank with a plug if you needed to drain and you could basically feel around the entire tank!
ThanksUnless they have changed the design of the G740 with the island bed, access to the fresh water tank is gained by removing the two drawers in the bed end nearest the washroom. With the drawers out, there may or may not be a lift out panel in the floor and the fresh water tank threaded cap will be visible. Bit of a hands and knees job but doable and it gets easier each time you do it.
Hope this is of some help.
And there's no point in asking me eitherIt may be in the filler tube and not the tank, don't ask me how I know!
