1. MotorhomeFun The best Motorhome Club in the World
    Register to remove adverts Register Here
    Welcome to Motorhome Fun
    MotorhomeFun is a large community of motorhome and touring enthusiasts. Our website is the busiest of its kind. It serves as a meeting place for thousands of members who share their knowledge of motorhomes and travel, as well as arrange rallies in the UK, Europe and beyond.
    It's easy to join us and takes just a minute
EHU
Discussion in 'TECH/MECH GENERAL' started by kickstart, Feb 13, 2013.
  1. kickstart
    kickstart Funster
    Dec 13, 2008
    365
    58
    south yorkshire
    I thought if I had left my motorhome pluged in that even if my leisure battery was a little tired,all my electrics would work but when I checked this morning not enough power to turn internal lights on..... Is this possible ? by the way the EHUI light is on,on the control panel. I replaced the battery about 3 years ago Varta.
  2. rainbow chasers
    rainbow chasers Funster
    Oct 30, 2009
    3,747
    1,715
    Mid Cornwall
    Is your charger working? Even with a dud battery, it should be enough to power up lights. Halogens can drain quite quickly, but others should be fine. I would test the charger and see if it has been charging or not.
  3. kickstart
    kickstart Funster
    Dec 13, 2008
    365
    58
    south yorkshire
    No I mean even whilst still on EHU
  4. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    1,685
    691
    Warwickshire
    Two questions: has this happened suddenly or has a weakening of 12V capability been developing over time; what type of charger do you have?
    I may not have any bright ideas, but this info may help others to diagnose the problem.
  5. oldun
    oldun Funster
    Mar 23, 2008
    734
    163
    St Neots
    If its on EHU then the EHU should provide power for the van plus battery charging. So he lights should work no matter what state the battery is in.
    Are you sure that power is reaching the internal distribution unit?
  6. Sidney
    Sidney Funster
    Jan 27, 2013
    739
    412
    Stamford
    Daft question... Is the charger on?
    On my van you plug in a EHU and you get 240v.
    Switch on the charger unit and you'll get 12 volt lights, pump etc. If charger is on you could remove the battery and the 12v and mains circuits would work from the inverter.
    So are you sure the charger is on?
  7. joner8888
    joner8888 Funster
    Jan 4, 2012
    2,099
    1,826
    somerset
    There is a switch on the top of my charger box ,under a seat--if i push in a duvet ect it can turn it off, may be that?
  8. Wildman
    Wildman Funster
    May 30, 2008
    11,107
    4,973
    Ilfracombe, Devon
    From the Burstner manual.
    12V power suppy does not work in 230V operation.
    Causes.
    1)12V supply switched off
    2)Battery cut-off switch on the transformer/rectifier is switched off
    3)Charger module in the transformer/rectifier is defective
    4)230V automatic circuit breaker has triggered
    5)Jumbo flat fuse (50amp) in the living area battery is defective.
    My guess would be that a flat battery is drawing too much charging current and has blown the 50amp fuse as in number "5"
    anyway there is the list of where to look. My book does not list your model but I assume the electrics are much the same.
