Chip fryer oil ? (1 Viewer)
scotjimland
2,086
9,023
Suffolk Coastal District, UK
Timberland
I've had trouble with oil foaming in my chip fryer .. it went right over the top and down the worktop.. it wasn't too full nor the potatoes wet.
This is usually down to being old or contaminated oil ..but it's wasn't that old.. and still looked clean.. so I changed it..
Low and behold a couple of weeks later it is starting to foam again .. :Doh:
I don't mind changing, but am I using the wrong oil.. I usually buy the cheapest vegetable oil..
Is there a specific oil for deep frying .. a non foaming oil ?
Minxy
32,489
66,013
E Yorks
Carthago Compactline
It could be that the cheapest oil isn't of a brilliant quality and over time, along with the moisture from the items being cooked, the water builds up. We use whatever oil we have at the time, but I prefer sunflower to vegetable, so if there isn't much of a price difference I'll go for sunflower.
I could also be the spuds that you're using to make chips, some have a much higher moisture content than others, also if you have had the oil slightly under the ideal temperature you'll find that some bits will drop off the spuds and contaminate the oil and make it more likely to bubble too. Even if oil looks clean, it is still a good idea to strain it to remove the bits sitting in the bottom of the pan as these, quite apart from burning eventually, can keep the temperature lower than it should be.
Alternatively are you sure you're using cooking oil and not fairy liquid! :ROFLMAO:
490
443
Lincoln
Van Conversion
We use one of these now...No oil at all and cooks most things in about 10 - 15 minutes.
http://www.ebay.co.uk/itm/Philips-H...=UK_HGKitchen_SmallApp_RL&hash=item2c7e50c117
Feb 22, 2008
12,258
44,933
Norfolk
Nearly Tugging
Since 2004
We use rapeseed or vegetable oil in the large fryer at home and lower the old basket slowly :RollEyes:
scotjimland
scotjimland
2,086
9,023
Timberland
Thanks for replies and suggestions.. but none really explain why relatively new oil should foam when cooking..
I do filter it.. although last time it was foaming before I needed to.. it is a modern semi commercial fryer.. made by Buffalo with a proper heat control.. so not cooking at wrong temperature.
Broken Link Removed
I always use Maris Pipers bought from our local farm shop in a 25kg bag .. great all rounders, maybe they have more moisture this year due to weather ?
and no.. I don't use Fairy.. that's the kitchen skivvy's dept. :winky:
490
443
Lincoln
Van Conversion
Is it good, how do the chips come out? Do you use it for anything else?
We love it.
It was a prezzie from our daughter at Christmas and it's been used at least once or twice a week since.
It does oven chips really well and they come out nice and crisp.
I think you'd need to spray "Proper" chips with olive oil first if you wanted the same finish though.
We use it alot to crisp off baked potatoes after cooking them in the microwave.
You can cook almost anything that can be deep fried or oven baked as far as I know.
We've used it for scampi, fish fillets, croquet potatoes etc all with great results.
It's easy to clean too if you do it after each use.
Only downside is that it fills the room with the aroma of whatever's being cooked. :thumb:
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
scotjimland
scotjimland
2,086
9,023
Timberland
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
I have just glanced through some of Googles answers very informative:thumb:
geo glasgow
292
274
Glasgow
Auto-trail cheyenne
i use this u can put
pies bridies pizza slices sausages and its like an oven in 1/4 time
chips is a tablespoon of oil its the dogs bllx...
Broken Link Removed
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
On and off since 1983
I've always used one of these..... no mess, no cooking smells in the kitchen..........a bit dearer admittedly...........
davejen
1,861
1,235
Preston
Given up travelling
Since 1992
Last time my cooking oil foamed was because I'd accidentally used wood shampoo :Doh:
What the hell is WOOD shampoo?
Do you wash tree branches with it?
Intrigued, Dave:thumb:
scotjimland
scotjimland
2,086
9,023
Timberland
Living in the sticks our nearest chippy is a 20 mile round trip.. and at £1.80 a pop.. makes for an expensive chip.
Not complaining.. we also have no crime..:Smile:
besides, you can't beat home made chips.. and not the frozen crap either.. proper ones made with spuds.
wasp
1,724
18,180
Warsop
None gone caravannin
We got one of them Phillips air dryer things we cooks chips baked tattys
fish, fish finger pizza slices and garlic bread probably some stuff I don know about (cos I only watch), the chips tho is brill we just chuck cut chips into bowl an coat them wi about a tablespoon of oil,toss em about a bit an chuck em in the air dryer, mmmmm very nice,also we can take it in the MH to cook with.:thumb::thumb::thumb::thumb::thumb:
