Chassis extension on Rapido (1 Viewer)
Aug 21, 2014
570
1,093
Isle of Wight
Rapido A class
20 yrs on and off
:smiley: Advice please fellow Funsters, we've been and gone and done it again :smiley: Have part exchanged our current forever van for a Rapido 840f and would like advice about fitting a carrier for small motorbike and this would mean extending the chassis. Does anyone have any experience/advice to offer please :smiley: We're very pleased with the van so it won't be a big deal if it's not a good idea, just playing around with ideas :smiley:
43,315
49,369
First, you need to get underneath and see if its already been extended.
If it does have extensions then I would say forget it.
Also, it may be an ALKO chassis which requires bolt on extensions...not welded.
Welding will destroy the galvanised coating then the rot sets in.
As a last point, the chassis may be a lot higher than the lower edge of the rear valance/skirt making extensions too high behind the skirt to fit a towbar or rack brackets.
The last one I made had to be lowered 5" to clear the skirt.
2spritelyislanders
Aug 21, 2014
570
1,093
Isle of Wight
Rapido A class
20 yrs on and off
:smiley: Thanks pappajohn :smiley: Nowhere else but Fun would you get such a quick response :smiley:
Aug 6, 2013
11,953
16,567
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
My Hymer has the usual floor support extension to the chassis. The towbar, made from steel section that would do justice to the Forth Bridge, bypasses the original extension and bolts the the main chassis. Two 10mm bolts for each rail. The steel sections used are 120mm x 10mm joined at the rear by box section that's at least 75mm x 75mm onto which a short extension is welded to accept the towball mounting plate. It would be more than capable of carrying a small motorbike. I'd be tempted to approach a motorhome towbar manufacturer for a custom build. Shouldn't cost much more than having a towbar made.
Oct 5, 2012
4,283
9,569
Ayrshire
Carado T132
5 years, feel free to ask me about the Carado!!
I think there was a post showing a towball mounted short 2 wheeled trailer designed for exactly this purpose? I can find it but it was posted in the last couple of weeks or so!
Oct 20, 2010
2,248
37,616
Burry Port South Wales
Since 2003
I would email Rapido and ask the question, give them model number, vin number etc, the address is info@rapido.fr marked for the attention of Anthony Pfaff, he has been very helpful to us in the past. (y)
Ed
Jul 29, 2013
9,069
18,472
Salisbury
Hymer B678DL A class
since 2011
Gary
Towbar Fitter From Bournmouth did a brilliant job with our Hymer Exsis got the Alko type approved and he fitted it with van on my driveway in half a day with all the electrics etc he is very thorough.
Call him on this number 07778 343464
He really has got a good reputation and gets most of his work by word of mouth.
Aug 6, 2013
11,953
16,567
Kendal, Cumbria
since 1999
My thoughts were someone bolting/welding to the existing extensions, which are barely substantial enough to support the floor never mind a towbar.
On mine if Hymer had had the foresight to fit a towbar it would easily have replaced the (as you say - flimsy) extensions they've used.
