Canon 400d AE bracketing (1 Viewer)
ShiftZZ
21,383
84,555
Dark Side of the Moon
I am messing around with ae bracketing, the instructions are a bit vague,,,
Changed the settings, set the AE settings, but, I am only getting the one pic...
Any suggestions?
Dave
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Since 2004
Dave generally if you set the camera for bracketing, you set the amunt I.E. 1/2 stop over and 1/2 stop under the standard exposure. You then take 3 pics. there will be 1/2 stop difference in exposure from shot to shot.
Some cameras like mine will bracket up to 5 shots or more.
Hey that was sensible for a nutter. :Eeek:
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Since 2004
Should have said Dave YOU have to take the number of shots you have set for bracketing e.g. 3, 5 etc.
Oh and do not forget to turn bracketing off when you are finished!!! :thumb:
ShiftZZ
ShiftZZ
21,383
84,555
Ken
I have done that +1 % -1, press set, then take a pic, it only shows/stores one. The Instrcution manual is a bit so so..
Select [AEB].
* Under the [m] tab, select [AEB],
then press <Set>.
2 Set the AEB amount.
* Press the <> key to set the AEB
amount, then press <Set>.
*When you press the shutter button
halfway, the <h> icon and AEB
amount will be displayed on the LCD
monitor.
3 Take the picture.
* Focus and press the shutter button
completely. The three bracketed
shots will be taken in this sequence:
Standard, decreased, and increased
exposure.
Please can someone help before Old Mo comes with the answer I would never live it down..
Q. Does it automatically take 3 pics?
Jim
Ringleader
Jul 19, 2007
36,403
130,782
Sutton on Sea, UK
Adria Panel Van.
Since 1988
You need to take the three pics, generally the first will be over exposed, the second, correct the third under, but you'll quickly learn that this is not a very good way of taking pictures. Better if the Auto bracketing is done in one direction, for example, you know that the meter is going to be fooled by a bright scene and you want to compensate. Your camera should let you choose 3 different amounts, 3rd stop over, half over and a full stop over, ie all over, rather than the standard, 1 over 1 on and 1 under. Once you apply the thought to do this you'll find you get better results in manual mode and doing the bracketing yourself. :thumb:
Jim
Ringleader
Jul 19, 2007
36,403
130,782
Sutton on Sea, UK
Adria Panel Van.
Since 1988
Some Canons did take the three when in High Speed burst mode, Not au fait with your model but I'm sure you need to press the button three times.:thumb:
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Since 2004
If your camera is like mine Dave it will automatically set the bracketing you want. It does not take 3 or whatever photos YOU have to press the shutter however many times you have bracketed for. It will auto set the exposure to what you set in bracketing. :Smile:
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Since 2004
Try it, set for bracketing 3 shots. At least one stop over and under so you can see the difference. Take 3 shots of the same thing and when you view them in the pooter you can see the "correct" exposure plus one darker and one lighter. :Smile:
656
1,052
290
The universe
The trouble with using the Canon to auto the HDR is it looks cr4p! Even the Nikon does a bad job. You need to take the best parts of the 3 pics -1EV +0EV +1EV and merge them in Photoshop or Elements. Just my view, someone will disagree but HDR is very subjective. :Smile:
Gaz
403
1,079
cambridgeshire
since june 2005
i have a programme that uses one photo to do hdr.
it is oloneo photoengine
MikeandCarolyn
2,170
1,468
Worle,North Somerset
Since 2009
If the drive mode is set to <u>, you must press the shutter button three
times. When <o> or <i> is set and you hold down the shutter button
completely, the three bracketed shots will be taken continuously. Then
the camera will stop shooting. When <j> or <l> is set, the three
bracketed shots will be taken after a 10-sec. or 2-sec. delay.
AEB can be combined with exposure compensation.
Neither flash nor bulb exposures can be used with AEB.
this applies to my 40d.
You can download a manual at canon site.
for playing with HRD -Photomatix is a good prog (free trial)
You can either do the 3 shot bracketting thingy (sposed to be best) or,you could take one shot in RAW at correct exposure then ,when you open it make 3 JPG images adjusting only the exposureby -1,0,+1. If you adjust anything else it should be by the same amount on each image.
Have fun.
Mike.
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
When reading this I was praying old mo would have come up with a comprehensive full page report of a reply:ROFLMAO:
It really would have made my day:ROFLMAO:
