BBQ outside point. (1 Viewer)
williamb
42
14
Lancashire
a class
Hi I would like to fit a outside BBQ point the easiest way I can see to get gas supply from would be fridge gas supply can anyone tell me if this would be ok I intended putting a t- piece in to do this.:thumb:
Don Quixote
2,966
5,257
Lost in La Mancha, Spain
VW T6 Campervan
We had one fitted and I say fitted as I could have done it, but playing with gas I thought need some sort of back up.
We use it all the time when the safari room is up. Pay someone to fit it and give you peace of mind that it is done right.
williamb
williamb
42
14
Lancashire
a class
Bbq
I don't know where piece of mind I have had two jobs done in the past by so called professionals. Damp check being one van one year old told tested and perfect(( had to go back to swift damp as a sponge took five months to repair)) next had sat-dish fitted noticed clothes in wardrobe wet(( fitter did not seal entry hole for cable)) so don't want any more professionals at this time. There most be some good ones out there but unfortunately I don't seem to get them.
hilldweller
605
36,108
Macclesfield
Zilch Mk1
From Aug 2007
In my MH all the appliance pipes are mighty thin. Look like they are sized for the job.
But I did have a blanked off outlet on the 4 switch main gas manifold, added extra tap and BBQ point. Job's a good 'un.
I used this one, a seriously proper job connector.
Link Removed
williamb
williamb
42
14
Lancashire
a class
Bbq
That's the exact one I have bought. The pipe for my fridge is 8 mm and has a single joint compression fitting just where I want it to be I was going to remove that and replace with t- piece so I think it should be ok.
weejohnw
238
84
Richhill
Started August 2008
Got a BBQ point fitted and it is a great job. No more need to carry out gas cylinder - however, getting someone to fit it means that the system can be pressure checked to make sure there are no leaks.
Go for it.:Smile:
jb0371old
465
408
Norfolk
Autotrail
1 year
fit it yourself, pressuirse the system then spray some water with washing up liquid in it and check for bubbles, or you can buy a can of proper leak detector spray, which is essentially the samr thing but around a fiver.
Don Quixote
2,966
5,257
VW T6 Campervan
I don't know where piece of mind I have had two jobs done in the past by [HI]so called professionals[/HI]. Damp check being one van one year old told tested and perfect(( had to go back to swift damp as a sponge took five months to repair)) next had sat-dish fitted noticed clothes in wardrobe wet(( fitter did not seal entry hole for cable)) so don't want any more professionals at this time. There most be some good ones out there but unfortunately I don't seem to get them.
Feel sorry for you as that would piss me off lots, however in Spain I have no problems finding professional people ( all be it Spanish people as the "Brits" rip the "Brits" off ).
Here in Spain when I have the yearly check done without the correct paperwork for gas/electric etc they will not pass the MH.
hilldweller
605
36,108
Macclesfield
Zilch Mk1
From Aug 2007
I'd suggest a valve in line just in case. If the bbq point jammed open ( very unlikely ) you'd lose your fridge too.
You'll have to suck and see on flow. Light up the bbq and see if the fridge fails. The bbq will take significantly more gas then the fridge.
Sep 3, 2009
1,529
6,266
NW Surrey
LHD Hymer exsis-i
lorger
9,632
90,362
Dumfries
Knaus Sun 650MEG
Hoping to fit one before Thursday when we head of on our hols, only thing is I have 3. 12 hour shifts to do so might give my local mobile guy a phone and get him to do it.
I was looking at one that had a red cut off valve inside the box where you push the BBQ pipe into, if doing it myself I would just stick a T in where the main pipe comes from the locker that way I would only need a couple of feet of pipe.
lorger
9,632
90,362
Dumfries
Knaus Sun 650MEG
This is the one I was thinking of mainly because I know someone who bought it and now doesn't need it.
Link Removed
Dec 6, 2011
11,470
25,059
South Wales
Coach built Adria
re fitting in the fridge line, we had a bbq outlet fitted by the dealer at new and it was tee'd into the fridge line. we have the Truma outlet.:thumb:
43,207
48,802
Bullfinch is best.
When turning off the connector has a ball valve and O ring, same setup as a washing machine tap, so unless the ball or O ring is badly worn or damaged it cannot leak.
The Truma type relies on a spring loaded plunger and an O ring.
Any dirt/grit on the O ring or valve seat will allow gas to leak.
grasscutter
2,448
8,361
East Wittering. West Sussex.
Hymer Exsis i588
Started in 1980
I did exactly as you propose. I removed the fridge vent and had easy access to the gas pipe.
Cut in a T piece and fitted a Bullfinch BBQ point into the skirt of the van. Checked it over with leak detection spray (washing up liquid and water). Whole job took about an hour.
However, if you don't feel confident get someone to fit it for you.:thumb:
winchester
13
11
abermule powys
c class
since 1998
BBQ
I want to do the same and take it from the fridge with a t piece alsoIt should be possible
Don't see why not
TheBig1
17,509
42,755
the only point I can see to mention is that you are then relying on just one isolator valve. if the fridge or bbq point need to be valved off, you lose the gas supply to the other
dont tee in too near the fridge connecter either as you will make it harder to service the fridge. allow enough flexibility to be able to slide fridge forward to disconnect
another easy access point to tee into is often the gas locker. just make sure to include an isolator. bbq points have been known to leak after use, so instead of shutting off all gas to the van, just turn off the branch affected:thumb:
Ridgeway
3,624
6,054
Lausanne
NiBi Arto 85E
Since 2012
Good thread, think ill add this one to my list.
Might T in just after theTruma MonoControl in the gas compartment.
Apr 12, 2011
662
652
Lincoln
Burstner ixeo t 590
4yrs
Hi don"nt use washing up liquid as the corgi[gas safe] inspector pulled me up on that and i am sure that its illegal to touch gas
Techno
Jul 28, 2010
15,475
20,752
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
I fitted mine into the cooker supply on my previous van (Autocruise Starspirit)
On my Rapido I've T'd off the underslung
Techno
Jul 28, 2010
15,475
20,752
May 2010
I do all my own work as I am more than capable in all manner of craft skills. I was fortunate to have a PROPER apprenticeship in the 70's. I am always well aware of my own ability and never undertake anything that I am not confident of.
My experience of dealer and professional work is very negative.I've found plenty of examples on my current van that I have ripped out and re done correctly.
Conclusion
Don't assume that because you are paying that you are getting a quality job, always use people who are highly reciommended (plenty of that on here) and the only way to be 100% satisfied is to do it yourself if possible.
Don Quixote
2,966
5,257
VW T6 Campervan
Conclusion
I to was fortunate to have a PROPER apprenticeship in the 70's, but I´m not sure what that has to do with fitting a BBQ point. I'm also very capable in many areas ( jack of all trades - master of none ) but there are many on here that do not or can not do this sort of work, so look for advice on here.
Your experience of dealer and or professional work is your experience and partly ruled by your need to "do it your way" as again many owners would not look for examples of work in their MH, but simply just get on with using their MH.
I have nothing but respect for the local MH dealer here were I live and the workshop attached having had work done to a very high standard.
Your conclusion is partly right never assume anything, however doing it "yourself" - this for many could / would / might not be 100% correct even if they are satisfied.
Don Quixote
2,966
5,257
VW T6 Campervan
It's to do with gas and no certainty of quality of work just because you pay to have done.
This was a professional job :ROFLMAO:
My remedial work
Andy it is not a "dig" at you in any way, my point was and still is for many the first photo would do the job fine and many owners would never even look at it...... The second photo is the way you and I would have done it, but at the end of the day both do the job. Thats my point, not a dig at you.:thumb:
