Morning all,
I am going to be fitting a Solar Kit to the MH and also adding a second battery to create battery bank, I have a few questions that I hope some of you can help me out with.
1) Does the second battery in the bank have to be the AMP rating at the first?
2) When connecting the two batteries what gauge cable should I use?
3) When connecting the solar charge controller to the battery bank am I correct in thinking that you connect the positive to one of the batteries and the negative to the other to ensure even charging?
4) The MH battery charger is currently connected to one battery do I need to connect this across the two batteries as mentioned in point 3 above to ensure proper charging?
Any advice most welcome
